HID interface - 4033 / 4033BGN / 4033BGN00
Interface adapter that converts Wiegand data to F2F
http://www.hidglobal.com/documents/casi ... _ds_en.pdf
http://www.rfideas.com
http://www.rfideas.com/products/wiegand ... /index.php
http://www.erik-nielsen.com/pdfs/cx-ser ... ge-low.pdf
Wiegand/F2F Adapter allows you to connect Wiegand output proximity readers to CASI® Reader Processor boards.
Connect industry standard Wiegand readers to a CASI® 8RP interface board in any Micro/5® Control Panel. One Wiegand/F2F Adapter is required per reader, typically to be installed near the door location. Proximity readers (or any other Wiegand output reader) combined with the adapter, provides end-to-end supervision of the data cable, meeting the original CASI® system specification. The Wiegand/F2F Adapter duplicates special functions provided by CASI® systems such as Request-to-Exit (REX), door switch status, and door strike output.
use the right cable - Cable Recommendations = Alpha 1295C, 22 AWG 5-conductor
SW1 SWITCH POSITION
........ON........................... OFF
1..... Reserved .....................Reserved
2 H10310 H10301, H10302, H103XX (Corp. 1000)
3 HID reader Supervised HID reader Non- Supervised
4 .....2-state Supervised..... Non-Supervised
TB1
1...+12 VDC Power
2...-12 VDC Ground
3...Beeper Control
4...LED Control
5...Data 0
6...Data 1
7...Exit DI Switch
8...Exit DI Common
9...Door DI Switch
10..Door DI Common
TB2
1....+12 VDC Power
2....-12 VDC Ground
3....Door Strike Control DO
4....Reader Data 1
5....Door Strike Relay Normally Closed
6....Door Strike Relay Common
7....Door Strike Relay Normally Open
HID interface - 4033BGN / 4033BGN00
- interface_adapter.pdf
- CASI® Interface Adapter
Connects HID readers to CASI Access Control Systems • 4033 - (276.78 KiB) Downloaded 723 times
