EST2 - PRINTER switch settings - OKIDATA 192 182
EST2 EST3 - PRINTER switch settings - okidata 182 195 192 print
The printer can be turned on in the SDU (Stripe/2400) and it will not cause a trouble on the system.
The printer uses (Xon Xoff) to control data flow and paper out/trouble.
The default settings in the EST2 SDU is - 2400 even
SW1 - 1,2,4 OFF
SW2 - 1,2,4 OFF
Switch settings- Super Speed RS-232C ML184 Turbo/ML186
Switch Bank #2
Switch...............Function.....SW2-1...... SW2-2.......SW2-3.......SPEED
1...................... baud rate...ON........... ON............ON........... 19,200
2..................... selection... OFF...........ON........... ON........... 9,600
3...................................... ON........... OFF...........ON........... 4,800
....................................... OFF.......... OFF...........ON........... 2,400
....................................... ON........... ON........... OFF.......... 1,200
The printer will cause the EST2 panel to go into ground fault if the 110ac plug has a ground lug, remove it.
switch settings ml186 serial card.pdf
(3.4 KiB) Downloaded 580 times
PT-1S Printer Switch Settings. Tech_Fax_No_010002.pdf
(190.56 KiB) Downloaded 592 times
