EST3-SDU - DB Conversion Error-External Response Longer than
DB Conversion Error - External Response Longer than 3000 bytes for device
Bottom line, use Command files
The DB Conversion is the compiling of the database to make a file to be loaded into the CPU
The files are - Cab1.bin,Cab2.bin
The overall file size is to big to fit in the CPU's memory, Command Files will help
