Hi all,
Has anyone used FSB-PC before?? please advise how to import the addresses to the FSP-PC configuration software.
EST3 to BMS Communications Bridge FSB-PC
Re: EST3 to BMS Communications Bridge FSB-PC
give me the details or the points to be monitored by BMS i will configure it for you..
I still didnt run the fire alarm panel. I'm still in the installation phase. If u can tell me how to deal with such device it would be good.
what details you want, i can get some data from an existing project so that to get familiar with this device.
thank you
thank you
You can give me which device logical address of fire alarm to be monitored and what kind of communication to be use between fsb-pc and bms.
Its either one of this protocols:
Bacnet-ethernet
Bacnet-ip
Modbus
Lonworx
Etc...
Bacnet-ethernet
Bacnet-ip
Modbus
Lonworx
Etc...
Can i use 2 protocols simultaneously, i mean i want to interface with two systems using 1 FSB-PC, but each system using separate protocol.
No, cause every protocol have different configuration table.
i've attached a sample of the logical addresses
- LOGICAL ADDRESS.CSV
- (8.34 KiB) Downloaded 1185 times
Do any protocol sends ASCII data ???
here's are one sample for configuring Bacnet IP protocol.
- sample.csv
- (16.63 KiB) Downloaded 1229 times
