Hyper terminal to emulate printer.
daprofit
Post by daprofit »
I came across a EST2 with a busted LCD so I was able to use hyper terminal to emulate a printer.
I came across this swapping an EST2 out for an IO500. There are many situation it can be of help.
I did not put any information on how to properly set this up. You can call tech support and they will assist certified technicians in the event you would ever need to do this.
The link below is just showing how it works. Hopefully someone will benefit from this.
http://youtu.be/5MC28th_B-4
Y_Knot
Re: Hyper terminal to emulate printer.
Post by Y_Knot »
For EST2 the settings should be:
9600 baud rate
8 data bits
even parity
1 stop bits
none flow control
