SuperDuct 4-Wire Controller With RTS151
Posted: Wed Dec 30, 2020 8:33 pm
Wiring an EST four-wire superduct controller with a System Sensor RTS151
2 conductor for the duct trip
4 conductor for System Sensor RTS151 test switch
green and red LED will work
rts151
1 red (red LED)
2 black (common )
3 yellow (Test/Reset)
4
5
6 green (green LED)
4-Wire Controller
15 red (red LED)
2 yellow (Test/Reset)
19 green (power/green LED)
20 Black (Common)
https://edwards-signals.com/files/31006 ... ersion.pdf
MODELNUMBERS
TSD-CJ, TSD-CJ24,ESD-CJ, SD-CJ
4-W controller with RJ-45 modular connectors
TSD-SJ, ESD-SJ,SD-SJ
4-W smoke sensor with RJ-45 modular connector
TSD-4WJ, TSD-4WJ24, ESD-4WJ, SD-4WJ
Combination 4-W controller and sensor with RJ-45 modular connectors
TSD-CJG
4-W controller with RJ-45 modular connectors and cover gasket
TSD-SJG
4-W smoke sensor with RJ-45 modular connector and cover gasket
TSD-CT, TSD-CT24,ESD-CT, SD-CT
4-W controller with terminal block connectors
TSD-ST, ESD-ST, SD-ST
4-W smoke sensor with terminal block connector
TSD-SJCO2
4-W sensor with RJ-45 modular connector and TSD-CO2 sensor module
TSD-STCO2
4-W sensor with terminal block connector and TSD-CO2 sensor module
