EST io64 software
EST io64 software
I need io64 software. Can anyone send me?
Re: EST io64 software
EDIT : Sorry after running that software I see it is for a different version of the IO panel.
I have not used this version but you can download it here;
http://edwards-signals.com/index.cfm?pg ... l=25&sid=0
Then select "Fire Panel Programming Software"
"FSA-CU Setup v3.3.zip"
to fire works I downloaded the fsa-cu from the link you posted, the software cannot program the io-edwards it says, wrong panel brand
do you have a 3.3 software for io? thanks
yes the software cannot working in the panel io 500 or io 64 because the software used by edward fire shield( fs -cu) diffrent from (io-cu) from ge if u want the software pm me bongky17@gmail.com
