Page 1 of 2
IO-CU IO64 IO500 software download
Posted: Wed Jun 14, 2017 9:20 am
Download
IO-CU_Setup_3.5
IO-CU_Setup._3.4
IO-CU_Setup4.0
IO-CU_Setup4.1
FSA-CU Version 3.5 and Firmware Version 2.3 Release Notes
https://www.edwards-signals.com/index.c ... l=25&sid=0
remember:
WHEN YOU INSTALL AND RUN FOR THE FIRST TIME, YOU CREATE YOUR OWN PASSWORD
search words:
EST io64 software
IO500 IO1000
I/O 3.5 software
I need IO-CU ver 3.5
Re: IO-CU IO64 IO500 software download
Posted: Sun Oct 22, 2017 7:30 pm
by vectrasoundz
Hi, any chance you have 4.1?
Posted: Mon Sep 24, 2018 12:08 pm
by AZFIREGUY
Does anyone have 4.11 IO-CU software available?
Posted: Tue Oct 01, 2019 10:57 pm
by APEN
Hello does any one know what is the latest panel version for iOS 500. I’m getting a 5003 error code when trying to write to the panel, only then I can read from panel just fine but not write. I’m using io-cu 3.1 any help much appreciated
Posted: Mon Oct 28, 2019 12:58 pm
by isatronix
hi
the latest version is 4.2 for IO-CU and VS-CU
the version of slc loop card are incompatible,
if your version data base panel is you need upgrade
Version 4.2 firmware compatibility
Panel firmware version 4.2 is not compatible with iO-CU 3.0, 3.1, 3.2, 3.31, 3.32, 3.4, 3.5, 4.0,
4.1or 4.11. If you have a panel with version 4.2 firmware, iO-CU version 4.2 or later is required.
Version 4.2 firmware is not compatible with old loop (SLC) cards. Your panel must have the
iO-SDC1 or iO-SDC2 SLC interface cards installed.
regards
Posted: Wed Mar 31, 2021 9:54 am
by Overreved
I cant seem to openm the IO software because its a xxx file anyone run into this.
Posted: Thu Nov 18, 2021 7:34 pm
by Protecse
Hola
ME PUEDEN APOYAR CON EL SOFTWARE PARA PROGRAMAR EL PANEL iO1000
srcontres@gmail.com
Posted: Thu Nov 18, 2021 7:41 pm
by Protecse
Necesito IO-CU ver 3.5
Posted: Thu Nov 18, 2021 8:41 pm
by FVILLA
Posted: Tue Dec 28, 2021 10:24 am
by jackglux
Can anyone resend the download for IO-CU V 4.11?
Can I use V3.5 to program a panel with V 4.11 software?
Thank You
