Looking for IO-CU 3.5
Kingspade
Post by Kingspade »
Will trade VS-CU Ver3.5 for IO-CU Ver3.5
Firetech1701A
Re: Looking for IO-CU 3.5
Post by Firetech1701A »
I am in need of the VS-CU and the I.O 3.5 I have 3.4 and the panel I will be working on is 3.5. Any other software you looking to trade for.
pyrosucks
Post by pyrosucks »
If you have VS-CU 3.5 and IO-CU 3.4 currently installed, try this.
Copy the VS-CU.exe file into the IO-CU directory.
Delete the old IO-CU.exe file
Rename the VS-CU.exe file to IO-CU.exe
Run program normally. I have used this to program and load 3.5 panels sucessfully. Only difference is it will have the vigilant logo in the software.
I assume this will work in reverse as well if you have IO 3.5 and VS 3.4
