Download
IO-CU_Setup_3.5
IO-CU_Setup._3.4
IO-CU_Setup4.0
IO-CU_Setup4.1
FSA-CU Version 3.5 and Firmware Version 2.3 Release Notes
https://www.edwards-signals.com/index.c ... l=25&sid=0
remember:
WHEN YOU INSTALL AND RUN FOR THE FIRST TIME, YOU CREATE YOUR OWN PASSWORD
search words:
EST io64 software
IO500 IO1000
I/O 3.5 software
I need IO-CU ver 3.5
IO-CU IO64 IO500 software download
Re: IO-CU IO1000 software download
Any one have IO-CU 4.4
Re: IO-CU IO64 IO500 software download
Hi, any chance you have 4.1?
Does anyone have 4.11 IO-CU software available?
Hello does any one know what is the latest panel version for iOS 500. I’m getting a 5003 error code when trying to write to the panel, only then I can read from panel just fine but not write. I’m using io-cu 3.1 any help much appreciated
hi
the latest version is 4.2 for IO-CU and VS-CU
the version of slc loop card are incompatible,
if your version data base panel is you need upgrade
Version 4.2 firmware compatibility
Panel firmware version 4.2 is not compatible with iO-CU 3.0, 3.1, 3.2, 3.31, 3.32, 3.4, 3.5, 4.0,
4.1or 4.11. If you have a panel with version 4.2 firmware, iO-CU version 4.2 or later is required.
Version 4.2 firmware is not compatible with old loop (SLC) cards. Your panel must have the
iO-SDC1 or iO-SDC2 SLC interface cards installed.
regards
regards
I cant seem to openm the IO software because its a xxx file anyone run into this.
Necesito IO-CU ver 3.5
