Altonix NAC Power Extenders - over view
www.altronix.com NAC Panels
The TOP feature of the Altronix NAC panels is its (Signal Circuit Trouble Memory)
identification of an intermittent/fault (short circuit, open or ground) which has previously occurred on one or more signaling circuit outputs. LEDs indicate/identify which output the fault has occurred
All of these NAC panels are every similar
AL6xx - 6.5 amps
AL8xx - 8 amps
AL10xx - 10 amps
AL842 and AL642 - One battery backed-up 1.0 amp auxiliary output, and one Non-battery backed-up 1.0 amp auxiliary output.
AL1042, AL842, AL642 - If you need class A circuits use "4 class A circuits" DO NOT BUY THIS model if not need. the wiring will confuse the best of us.
These NAC panels are made of two boards the Power board and logic board.
The logic broad is where the circuits are landed. Three different boards - AL800LGK9, AL800LGK9E and AL842LGK
AL842LGK are the 4 circuit class A boards
Models:
AL600ULADA - Replaced by AL602ULADA
AL602ADA220
AL602ADA220J
AL602ULADA
AL602ULADAJ
AL642ULADA
AL800ULADA - Replaced by AL802ULADA
AL802
AL802ADA220
AL802ULADA
AL802ULADAJ
AL842
AL842ADA220
AL842ULADA
AL1002
AL1002ADA220
AL1002ADA220J
AL1002ULADA
AL1002ULADAJ
AL1042
AL1042ADA220
AL1042ULADA
