Re: Siemens Desigo/Cerberus Pro
Posted: Sat Jan 07, 2017 2:10 am
by vipincharles
firetruk wrote:Hi there,
Would anyone have manuals and the programming software for these systems?
U GOT IT??
Posted: Sat Jan 28, 2017 8:07 pm
by remi88
I could find the siemens MXL programing software, only runs on windows 98.
Posted: Sat Jan 28, 2017 8:35 pm
I ever programmed a MXL panel.
I just assumed that the software needed a key or something.
could someone enlighten me.
Posted: Tue Jan 31, 2017 11:52 pm
by Kmaysob
You will have to call in a Siemens dealer for the Cerberus pro and a Siemens corporate branch for any desigo work.
Both panels use software much like notifier does . There flat out, is no way to get it without being a dealer.
The mxl requires a permanent key from Siemens, but will be worthless unless you are a dealer . For dealer "a" to plug into a panel installed and programmed by dealer "b", would require a password of the day request by the customer. Once approved , a Siemens dealer will have to call in with the approval and take control.
The only Siemens panel that is non proprietary/open source is the fs-250.
Posted: Tue Jan 31, 2017 11:58 pm
by Kmaysob
remi88 wrote:I could find the siemens MXL programing software, only runs on windows 98.
That depends on the version . 10.03 & 17.02 were for Windows 98. Later versions worked with XP . We found a way around the windows 98 requirement years ago by using a dos based bootable flash.drive .
Posted: Thu May 09, 2019 11:34 am
by isatronix
Posted: Wed Jul 22, 2015 11:58 am
by firetruk
Hi there,
