recommended distance from valves supervisory switch and modu
Re: recommended distance from valves supervisory switch and
I generally put them as close as possible to the device you are monitoring, keeping in mind having room/access to service them later. There is maximum distance depending on the type/size wire you have, you would have to refer to the install sheet for the particular module you are installing.
peermoh80
Post by peermoh80 »
Hi All,
What is the recommended distance from FF valves supervisory switch and modules(Siga-CT1/CT-2).
