Trouble Item: Primary Audio Output Analog
pcoman
Re: Trouble Item: Primary Audio Output Analog
Post by pcoman »
Did you ever get an answer to this fix? I am having the same issue only my trouble code is 1140623.
Any help would be appreciated .
Sam
Post by Sam »
chek
0623 Primary Audio Output Analog 3-ZAxx
1. Open Audio NAC circuit, missing or wrong value EOL resistor
2. Shorted Audio NAC circuit
3. Output voltage jumper set wrong
kong
Post by kong »
Hi Team,
We have received the following trouble triggered on the EST 3. And noticed that the trouble will be trigger on certain day and the panel will self restore to normal mode after few days later. And since like an intermittent issue.
Meanwhile, we have also checked the condition for EOL and speaker looping are in normal. Could it be the devices faulty?
Would like to seek your advice/assistance on the remedy steps to resolve on this issue. Thank you very much
Fault Description: Primary Audio Output Analog
PCD Code: 02100623
