bad type detector
jmanizam
bad type detector
Post by jmanizam »
i am getting a trouble
comm fault
when checked in details it shows me BAD TYPE ACTIVE
serdy
Re: bad type detector
Post by serdy »
device that you attach to substitute different types, probably earlier device was a type smoke detector, then you change the type of heat detector. or replace any module type does not match the type previously module. try you first check its type, matching the previous type.
mikbz
Post by mikbz »
It's also can be result of shaky contact when the siga-led disconnected from the base therefore you the base type changed and you receive bad type trouble.
FireTech
Post by FireTech »
WHy type of Device? Phs,Ps? Is there an Audible base being used? Or relay base?
comm fault
