EST3 with PA system
joeljames
EST3 with PA system
Post by joeljames »
I have installed EST3 fire alarm panel and how can I integrate it ith PA system.? Sound needs to be played through my Fire Speaker.
Regards
Joel
Kmaysob
Re: EST3 with PA system
Post by Kmaysob »
I would imagine there is a priority override input or bgm input on the voice control. You would likely need a line matching transformer to bring the speaker level signal down to line level. That said, I hope you are not using the fire alarm as the pa system.
joeljames
Post by joeljames »
Hi
The PA system is using the fire speaker for sending their messages. Currently we have kept the AA50 on always only when Alarm comes the priority will change and fire sequence works. But the problem is in case if sound does not come from PA panel then our AA50 will go to BU condition.Once in BU(ORANGE light in top right of AA50) then nothing will work. Only after activating drill it will function.
I heard there is a module called SIGA-RM1, Please Advise....
Regards
Joel
