SIGA DSI PROGRAMMING
lts-maroc
Re: SIGA DSI PROGRAMMING
Post by lts-maroc »
Hello,
No answer?
what is the error
is it working just not mapping?
disable the mapping.
you can stop the display from showing monitor points, so no one will know
I just was mapping a older site that had siga-dsi smokes
it was killing me, I could not get the two maps to work right
so I gave up and disabled mapping and stop monitor point from going to the display
lts-maroc
Post by lts-maroc »
Hello,
The problem is in the configuration also, we can't add the device.
We add it as SIGA-PS, but the SDU tells us that it is not valid for the selected model.
Regards.
gmcorreia
Post by gmcorreia »
I think the problem is in the market place configuration. Try to modify market place on :
Configure >> Project >> Operation tab
The DS (photoelectric smoke) and DH (fixed temperature rate-of-rise heat) detectors are only available in these marketplaces: Arabic, Asia, China, International, and Middle East.
More information in SDU Help... search for "To understand DS and DH detectors"
lts-maroc
Post by lts-maroc »
Hello,
I have an installation on EST3 panel, I'm using SDU version 5.2, all the existing devices are old SIGA-PS , SIGA-HRS....
Another installation for new rooms has been made but with the SIGA-DSI detectors, when I read the map and try to add the new detectors, I'm facing error adding these new devices.
As I read in the datasheet of the detector, it is supported by EST3.
Note that I install also 5.31 version but the same error.
Please your help.
Regards.
