HI ALL
Greetings ,
ANYONE CAN HELP ME FOR PAS CAN I SEND SDU FILE TO HIM AND DO ONE EXAMPLE FOR POSITIVE ALARM SEQUENCE FOR ONE LEVEL AND I WILL DO OTHER , THE CAUSE & EFFECT HERE IN OUR PROJECT LIKE THIS BELOW .
1- If the panel is not SILENCED in 15 seconds the fire affected floor goes into Evacuation mode (Stage 2) and the above below floors in Alert mode.
2- If the panel is not RESET in 3 minutes the panel goes into full evacuation mode (Stage 2) automatically.
3- If two or more towers are present and the panel is not reset in three min the adjacent building should go into full EVAC mode in 5 min. (including all the interfaces).
THANKS , FOR HELPING
Re: POSITIVE ALARM SEQUENCE
this project has pas in it
the sdu is attached so you can download
http://www.thealarmtech.com/forum/viewt ... =pas#p4236
THANKS MR LEO FOR YOUR REPLAY
I CAN'T SEE THE SDU IN ATTACHED ONLY TXT FILE
if possible to send this sdu to " ibrahim7806@yahoo.com " I would be very thankful to you
thanks a lot for your helping ,
