How to configure a est3 panel from starting?
BlackHeaven
Post by BlackHeaven »
Re: How to configure a est3 panel from starting?
talk to me, from start?
the hardware, rules, labels
did you go to class, this you first project
an help in your company.
what are you looking for
BlackHeaven
yes actually i attended to training in last march and next January i ll be needing to commission a panel can you first tell me after adding cabinets and cards what should i do ... when i do version request how get cpu version and sdu version same ? and other card versions
when i do any changes before uploading do i need to do DB conversion ?
when im adding detectors and modules what is the procedure ?
no sure where to begin
one thing to keep in mind EST is always coming out with new versions of the SDU
someone just asked for SDU 5.40
your laptop and the panel may not be on the some SDU version
if you have a panel that is not in service (new install) play with it.
just down loading the panel can be nerve racking.
if you have a database and have questions post the database it is more likely someone will help.
YES DB conversion
adding detectors and modules? new system or old system, post it people will help
BlackHeaven
This is a new system still im installing the panels .. can you tell me the operation of backup amplifier and how and why to use CC2 modules for speaker lines
assuming the amps are EST3 ZA amps, one backup for a few amps?
all installed in the a cabinet, the backup amp is checked via a select in its setup.
the CC2 is not for backups, it is for two messages going out at the same time
sounds like a big job.
you need to send more info.
do you have prints, parts list, sequence of operation
sequence of operation will tell you if CC2 is needed
are you sure the wiring is right
BlackHeaven
Dear sir
i have configured the panels now individually and now panels needs to be added in to network . i have connected class B network wiring for panels and still network panel communication fault appears in each panel .. this network has est3 and 3x combination all the est3 panels has same firmware
