What is this fault? Event Safe Failure
Nirujan
Re: What is this fault? Event Safe Failure
Post by Nirujan »
one of youe LRM not communicating steadily with CPU, Try to remove the modules and replug into the rail...
marcosjp
Post by marcosjp »
ok thank you I will try and put the result. A very good afternoon
mohandsyasser
Post by mohandsyasser »
Just dowenload the cpu
marcosjp
Post by marcosjp »
I'm doing the programming of a panel of EST-3, have the panel build a 3-CPU3 panel, PSMON 2, and 3 3SDDC1. I did the programming setting the ties in class B and enabled mapping ... it is central to the whole routine without any programmed device. The only error Trouble with the following description "0001 Failsafe event" if someone can help me with this thank ...
