How to Replace any modules in EST3
justinambrose
Post by justinambrose »
Hi All,
I am doing fire alarm system maintenance in my plant. We are using EST3 system. If I want to change any communication module like 3-RS232, I need to take out the CPU from the main power bus. So, the configuration and other programs we need to load again? I am asking whether the program erased or not?
Thanks,
Justin
Re: How to Replace any modules in EST3
all do respect you could not mess with the panel.
change out smokes, not a problem
the program will not be lost if you pull the cpu to replace the 232 board
fyi the 3-rs232 is not bad
is this a big system?
if the system does not come back up how bad will it be?
I would not touch it if I was you.
