SP - REPORTS, Bug-running reports (Select Archive/History)
Secure Perfect Report Bug
When running a badge report under the (Database tab) you will need to select the Archive or History Database for your report.
Bug: under the Database tab it will show the Archive Database is select be its the history database, you will need to select the Archive if you want it.
Remember All Ways check the Archive Database Size
