SP- Micro Utility Form, Firmware Version is YELLOW
The Mirco Utility form has a YELLOW indicator not GREEN,
this is because the Firmware in Secure Perfect for the micro is newer then in the Mirco
Open - Micro Utility Form, Right click the troubled micro - View/edit flash files, you will note the two micro versions do not match .
