Page 1 of 2
NFS Series Firmware/Application Code
Posted: Mon Nov 04, 2013 2:47 pm
by pyrosucks
Anyone have access to these files? I need to update firmware in a panel we service.
Re: NFS Series Firmware/Application Code
Posted: Fri Nov 08, 2013 4:55 pm
I maybe able to help you.
which panel is it for?
Posted: Sun Nov 10, 2013 8:49 am
by pyrosucks
NFS2-3030
Posted: Mon Nov 11, 2013 6:12 pm
I work for a notifier distributor now (jersey/phila area). that is why I have stopped answering the EST stuff.
the mother board does not have any firmware chips on it.
there is a "panel database version" for the mother board, which you need the new Verifire tool to load the panal with.
the LCM-320 "SLC" board does have firmware chips.
Posted: Fri Nov 15, 2013 10:39 pm
by pyrosucks
Are there any compatibility issues with the lcm version and the database version? (Do they need to match?) can i replace an lcm card in an existing system without having to be concerned with firmware versions?
Posted: Mon Nov 18, 2013 4:58 pm
If you have the old LCM-320 card you can swap out the square firmware chips.
if not you will need to have a notifier tech flash the card via the new verifire tool for the 3030.
Posted: Tue Nov 01, 2016 8:51 pm
by cmadradi
Leo,
I have the same problem, however I need to make a downgrade in a Notifire.NET system, it has 5 NFS2-3030 ant 14.0 database version, we need to change the NCA2 and the CPU. they have database version 23. However, the new database is not compatible with the firmware in database, so I need to program them with the Verifire TOols 6.1.
CLient only owns one of the 3030 and the NCA, so we do not have access to the other 3030.
DO you have the application codes that are compatible with database version 14 so we can downgrade the new cpu and the NCA and we can upload the converted version of the DB?
Regards,
Posted: Sat Nov 05, 2016 4:26 pm
can you call notifier tech support?
if not I will call and look into this
Posted: Tue Nov 22, 2016 9:34 pm
by Kmaysob
I am not sure if the 3030 can be downgraded that far. I have never gone below version 21. The nca is not able to be down graded. I went through this recently. In fact, notifier tech support will argue that you cannot downgrade a panel either. I argued with one of them for a few minutes, before he talked with the engineers and determined I was right. The only time I down grade, is to save a customer from having to upgrade their onyx work station.
