QS-Panel Password Levels
Posted: Fri Jul 02, 2010 5:22 pm
The QuickStart has 4 Levels of Passwords.
The default password for each level are: 1=1111 2=2222 3=3333 4=4444, the highest level is 4
The barrel Key on the front of the panel will log you into level 2
Level 2 will be able to disable/enable/activate devices
Level 3 can be change via the QS-CU program, If the default lvl 3 password has been changed, you will need to know it to load or retreive the panels database. without it you will be locked out of the panel for programming
If the lvl3 password has been changed and you do not know it, you can reset the panel (blank it out, you will lose all the database) with the Code Loader.
So you will need to rewrite the database/program, but you will not need to replace to panel.
To load the QS panel you need to be login in with a level 2 or higher. the front barrel key logs you in with a level 2 login.
Re: QS-Panel Password Levels
Posted: Thu Jan 05, 2012 9:08 am
by getech
You can try password 3253, this password it's like level 5 password.
With this password you can change password level 4, 3 , 2, 1.
Posted: Thu May 17, 2012 3:29 am
by kantula
Dear Leo
if i dont have old source and Pass, i can programming QS4 panel.
And i have a question.
with QS4 panel it can work with new detector SIGA2 of EST.
Posted: Thu May 17, 2012 3:33 am
by kantula
Dear Mr Leo
d you have QS4 manual programming Document or guide, Pls sent me
Posted: Thu May 17, 2012 3:53 am
by kantula
Dear Leo
I think in the EST system have a Io Series. why are you creat a topic for this panel ?
Posted: Fri Dec 14, 2012 5:27 pm
by shashishashu
[quote="kantula"]Dear Leo
Yes you can program it. Retrieve the database!
Only SIGA2-PHS , SIGA2-PS, SIGA2-HRS/HFS.
Posted: Fri Dec 14, 2012 5:43 pm
by shashishashu
getech wrote:You can try password 3253, this password it's like level 5 password.
Try 3783!!!
Posted: Thu Jun 18, 2015 2:38 pm
by Tom_Witt
Leo, will the EST QuickStart Codeloader nuclear option for clearing out non-default passwords work with a Mirtone QuickStart. If not, was there a Mirtone CodeLoader?
Posted: Tue Jul 21, 2015 6:07 am
by Nirujan
Any one know the Access level 5 password for est3 , if yes please help me...
Posted: Mon Oct 05, 2015 1:12 pm
by getech
Nirujan wrote:Hi,
Check on your phone and the letter correspond to a number so EST3 password level 5 is: 3783
