Adding an Annunciator?
Posted: Thu Sep 17, 2015 10:22 am
by higguns
Hello,
Just wondering if it is possible to add an annunciator to a quickstart panel from the front panel programming? the panel is already installed and working, but the customer is now renovating and was told by the AHJ that they need to add an annunciator. We have a used annunciator from a quickstart panel and would like to install it but need to know if it can be easily programmed into the system or if it will automatically recognize the new annunciator?
Thanks for your help in advance.
Re: Adding an Annunciator?
Posted: Fri Sep 18, 2015 5:55 am
you will need to use the QS program to add the annunciator
Posted: Fri Sep 18, 2015 9:20 am
by higguns
thanks for the quick response. will the software run okay on a windows 8 laptop?
Posted: Fri Sep 18, 2015 5:01 pm
by wadah
Depend on my Experience This QS Software Compatible With Window Xp-3 and Lower
Posted: Wed Oct 07, 2015 2:32 pm
by Y_Knot
You'll probably need codeloader, too. Just to make sure all CPUs have the same microcodes.
