QS CPU v2.5 program?
Sm1ggs
Post by Sm1ggs »
Is there an updated version of QS-CU?
If so does it need a key/dangle?
Having a problem loading a database into a v2.5 cpu.
Re: QS CPU v2.5 program?
2.5 is the latest and final version of QS-CU. QS panels have been discontinued for quite a while.
Sm1ggs
Post by Sm1ggs »
Well then, that brings up an issue I'm having.
Have a QuickStart CPU v 2.5. Old CPU is v1.81, db v2.5. I retrieved the database from the old CPU, replaced CPU with the v2.5. When I try to dump the database in the new CPU I get a "Transfer Error" popup on the PC, after qs-cu reaches 100%. CPU shows Need Database. I am able to successfully use code loader so I don't think it's a hardware (PC or cable) problem. This has happened with 2 "new" CPUs now so I can't imagine it's the CPU either.
Any ideas?
Thanks in advance.
load your panel with a known good 2.5 QS database see what happens.
I would maybe just rewrite the project. 2/3 hours? start with a clean project.
Sm1ggs
Post by Sm1ggs »
I'll give it a shot later this week and let you know what happens.
make sure you set the version correctly in the project configuration. If you uploaded from a 1.8 cpu and subsequently downloaded a 2.5 cpu without upgrading the database, it will cause problems. Also make sure all cpu's in the project are the same firmware version.
Sm1ggs
Post by Sm1ggs »
Just got off the phone with the area EST distributer and qs-cu v2.6 is needed.
I see tons of posts asking for that version on the forums with little response and a quick google search didn't turn up anything of interest. Guess I'm gonna have them come out and program it for us.
