EST ESA 2000 Panel NAC Outputs
higguns
Post by higguns »
Anyone know if the EST ESA 2000 (and the re-branded Mirtone M2000) fire panels can have the NAC outputs on the main board set as steady output for connecting strobes? From my reading in the manual the panel is set to pulse at 120 PPM (pulses per minute?) as default. It doesn't say in my manual how to change it that I can see.
We don't have the work yet (or permission to check the panel outputs with a meter). Just want to see if its possible to be configured as steady or not or maybe it already is?
Re: EST ESA 2000 Panel NAC Outputs
The output circuits on the esa2000 motherboard can certainly be programmed for steady output. Although all programming can be done from the display, it's VERY tedious. You really shouldn't mess with that panel, though, unless you have the rs232 interface card, and a program key to backup and restore the system images.
