EST3 SDU 3.6 Map fault - mapping can't complete
Posted: Thu Dec 28, 2017 2:45 pm
by julio.eng.uerj
Good afternoon
I have a mapping failure problem in the EST3 central. There was no change in the loop, nor devices, only removal of some detectors for cleaning. The problem is that mapping failed and after downloading the program to central, the mapping did not complete (stops at device 50, total of 104). When uploading the mapping, nothing appears. I already tried to perform reinitialize loop, dowloaded again, but had the same result.
Re: EST3 SDU 3.6 Map fault - mapping can't complete
Posted: Sun Dec 31, 2017 11:36 am
most likely one of the smokes you cleaned is not sit right.
I would remove ALL the smokes you cleaned check the base, look for anything that does not look right
and put back.
