If you need to put online the NETAXS-123 and 4 with the new Win-Pak 3.0 NETAXS Gateway template, you will need to upgrade the panel firmware, from 3.1.8 to 3.4.3, its a must.
NETAXS-123 will need a specific update for is firmware same for the NETAXS-2 and 4, so be carefull to choose the proper one.
Later on I will post the NETAXS Upgrade utility 1.1.10 to help with both firmware that will be needed to do the action successfully.
Gaeten
WinPak SE PE 3.0
WinPak SE PE 3.0
WIN-PAK® SE 3.0 and WIN-PAK® PE 3.0 Now Available
- L_WNPKINTD_D2.pdf
- (1.27 MiB) Downloaded 484 times
- L_WNPKPESEDV_D.pdf
- (230.51 KiB) Downloaded 339 times
