Lantronix UDS100 - Network communication devices for PW-2000
Posted: Sat Jan 31, 2009 5:56 pm
Network communication devices for PW-2000 series controllers
LANSRL100 RS-232 to LAN converter, 10/100 mbps
LANSRLU1 Lantronix UDS100 Replaced with -> UDS1100 / UDS1100-PoE or MSS100
Overview :The LANSRLU1 (UDS100) Device Server connects serial devices such as Security Alarms and Access Control Devices to Ethernet networks using the IP protocol family. The UDS100 connects these devices through a TCP data channel or through a Telnet connection to computers or another Device Server. The UDS100 uses the Internet Protocol (IP) for network communications and the Transmission Control Protocol (TCP) to assure that no data is lost or duplicated, and that everything sent to the connection arrives correctly at the target.
Honeywell Access Systems WIN-PAK 2.0 ip rs232 rs485 tcp tcp/ip
http://www.lantronix.com/
Re: Lantronix UDS100 - Network communication devices for PW-
Posted: Sun Oct 03, 2010 8:17 pm
Serial Programming through HyperTerminal
I find this to be the easiest way to program this device
1. On the Windows Menu Bar, go toStart > Programs > Accessories >Communications > HyperTerminal.
2. A Connection Description screen will appear, prompting the User to 'enter a name and choose an icon'. Enter a name and select OK.
3. A Connect to screen will appear. Under the category 'Connect using'. Select the COM Port in use with the UDS100.
4. At last a COM Properties screen will appear. Make the following changes:
Bits per second = 9600.
Data Bits = 8.
Parity = None.
Stop Bits = 1.
Flow Control = None.
5. Select OK. The user will then notice a blank screen with a blinking cursor.
6. To enter Setup Mode, while holding down the 'x' key, cycle power to the UDS100 (power off and back on).
7. When the device reports back information, immediately press <enter>.
8. At this point, complete steps #21 through #30 of the IP address procedure that beginns on page 5.
16. At the 'Your Choice?' prompt, Enter "0" then <enter> to go into Server Configuration.
17. At the IP Address prompt,
18. At the Gateway IP Address prompt
19. At the Netmask Number
21. At the 'Your Choice ?' prompt, enter "1" then <enter> in order to go into the Channel 1 Configuration.
22. At the Baud Rate prompt, enter 9600 then <enter>.
23. I/F Mode is not used, press <enter>.
24. At the Flow prompt, type 00 then <enter> in order to disable Flow Control.
25. At Port No (10001), type, 3001 then <enter>.
26. At the ConnectMode (C0) prompt, enter C1 for remote configuration then <enter>.
27. At the Remote IP Address prompt, if configuring the Remote UDS100 at this time, press the enter key four times so no Remote IP is assigned.
28. At the Remote (0): prompt, enter 3001 then <enter>.
29. Press <enter> through the rest of the menu options.
30. Type 9, <enter> to Save and Exit.
9. Upon completion,exit the Hyper-Terminal session.
